03-15-2016 04:37 PM
Trying to scan (MX920) on my MacBook Air with OSX 10.11.2
This has worked with no problem before. Now I try to get into the scanner through various methods and get the same error:
"An error occurred while communicating with the scanner. (-9923)"
It is printing fine. Connected via WiFi.
I have restarted both the printer and computer more than once. No change.
05-26-2019 07:45 PM
05-26-2019 09:59 PM - edited 05-26-2019 10:08 PM
Geoccar,
Are you a Mac or a PC? I am on a MAC. If you have a MAC, I suggest trying to use Preview to scan. When I use Preview I get a import from Canon TS910 servies. This is not the fix, but it maybe a workaround.
05-26-2019 10:06 PM
Dendyke, I am using a Mac on my wireless network. I am not having a problem now after I shut off my IP v6. I had a temporary problem the other week after I update the firmware on the printer. This time I rechecked that I have turned off IP v6 after the fiirmware update by turning it off again. I also deleted and readded the printer. That seemed to do the trick for me. I am not certain if geoccar is Mac or PC. HOw about you? Are you PC or Mac?
07-11-2019 05:45 AM
i'm fixed this error. Need disabled IPv6 in settings.
12-12-2019 12:28 PM
This is the answer. Works for my Canon ts9120 and OS Mojave when getting the error 9923 for scanning.
12-16-2019 10:14 PM
Amazing! So thankful to you!
I never would have known to go to IPv6!
Any idea why it had stopped being disabled? Good grief that was buried!
12-16-2019 10:31 PM
THANK YOU for taking the time to deliniate the exact steps!
Solved!
02-14-2020 12:12 PM
Same here, I can print fine but trying to scan throws "error 9923".
Running OSX Mojave 10.14.6 with a TR7520 over LAN.
02-26-2020 04:01 AM
05-20-2021 11:37 AM
Excellent. I've been trying to get the scanner working for two years now.
