Desktop Inkjet Printers
MX882 won't print single Quicken check?
Howdy y'all; My Canon PIXMA MX 882 printer worked fine for the first and second checks on the 3-checks-per-page page of checks. But when I get to printing the last check it doesn't pick properly and the check info prints on a blank page. The check go...
Scan multiple copies on one Scan To Folder Job
Can you scan once and have the job generate multiple pdf files in a Scan to Folder process.This would be much like choosing to print 5 copies of one document, but in this case you would scan the doc once, and 5 identical pdf files show up in the scan...
mbfromit by Apprentice
  • 4019 Views
  • 4 replies
MG6821 Does not turn on after being unplugged
I have a 1 year old MG 6821 that I unpluged and moved to a different location in the house.  Now the printer does not start at all.  All I get is a solid yellow light on the printer.  I have tried leaving the printer unplugged for 10 hours and then p...
Canon MX340 error message U163
I just replaced the black ink cartridge and I get the message "Check Ink" and an error code U163.  The color cartridge is dry because I do not use color.  I cannot copy or print.  Any suggestions would be very welcome!  Thank you!
MG6320 won’t print AFTER troubleshooting
Hi, my MG6320 printer stopped printing the other day. I’ve tried the cleaning and deep cleaning functions in setup several times. I’ve also cleaned out the printer head. Unfortunately, still no printing. It makes all the sounds as if it’s printing, p...
Bukimmy by Apprentice
  • 2569 Views
  • 2 replies
MX922 and legal size scanning and printing issues
Hi all, I'm new here and did a search but came up with nothing, maybe I'm just stunted!!! Heres my issue! I scan a legal size document, it's plans for a roject i'm working on and the document has specific sizes! The original legal document is perfect...
Loadie by Apprentice
  • 3282 Views
  • 3 replies
Canon Pixma MG6821 printer ink tank holder
When replacing an ink tank in my Pixma 6821 the ink tank holder was accidentally pushed to the left and is locked in that position and will not resume its proper location in the center or on the right so the printer will not operate. How do I get it ...
Pixma Pro-100 Not Turning On
I originally bought this printer for a small printing business in 2016 but never ended up using. Once just for a testing shot. It is not turning on at all. I bought this at Amazon and I can't seem to find any info on a warranty. What can I do?
Automatically Cropped Image - Canon Pixma TS6020
I have an issue when printing out images on my Canon TS6020. It doesn't matter if I use photo paper or regular paper or select "borderless" or "regular sized" when I print, both ways will mess up the image. Borderless will cut off/crop a significant ...
MG7520 Printer - copy and scan issues
When I scan or copy a document  the black  print comes out gray and  the  document is not sharp.  If I print a document from  a file or the internet,  It comes out  fine.  the black print is black and the document is sharp.    I am running windows 10...
csorchil by Apprentice
  • 2026 Views
scan
just purchased a Pixma MG3600.  Using my image garden, when scanning to my laptop acer aspire with windows 10 i get the message cant read this .pdfPlease help
