Scanning from MX710, sometimes PDF files are cropped.
I have a MX710 multifunction printer and when I scan a single page from the ADF, sometimes the resulting PDF is severely cropped. Any answers?
I have an event tomorrow night, I would like to capture images in color for later use but print onsite using Canon Selphy CP900. the Directions for the Selphy all setting must be done in camera. The 5D Mkiii Manual page 300 shows you can make this ad...
Hi I'm Jay,I'm using a Canon MX 922 as a home office printer, scanner,copier and fax. First question- When I try to scan a 30 page document I get an error saying there is paper stuck, but its the second page and should be getting ready to be scanned ...
Hello all, I have installed the drivers for the printer and they work fine, however I cant use the scanner and Ubuntu does not detect it. What am I doing wrong Thanx for you help in advance June
hi I printed off a bill today then after this I was unable to do more I was told by a tech I think he hacked my unit they wanted 179.00 to fix it. I did a systom restore I still cant print what is up please help this is new also cant fine driver for ...
Hi all, I have two Macbook Pro's, both running Mavericks. I have not installed any Canon printer software on either. On one of the macbook pro's, I can scan from my wifi connected MG6320 from the built in Preview app. On the other, I cannot. It ...
Hi,I've recently bought a Canon Pixma Mg4260 multifunction. I'm using a Mac laptop and as I don't have a disc drive I downloaded the software from Canons website, however I still cannot scan. The error message says "set the PC to start scanning". My ...
I've been using USB connection for a couple of years. Now I'd like to use WiFi to enable printer sharing among several devices. Do I need to load specific WiFi drivers or delete USB a USB driver? If not, I'd appreciate suggestions on how to turn u...
HP computers. Solution Menu EX does not have autoscan option on desktop.Correct 3 folders in Windows file.Here is the error message I get:Cannot open MP Navigator EX. Check the following points:1) the supported model of this software is as follows:Ca...
can't set my mg 3222 printer up as wireless, follow software and when it requires the ip address for my netgear router can't go any futher, does not matter weather dome auto or manual don
I need to print DVD label on Multi Flip paper stock on MX922. 183 mm Width x 270 mm Length with 11mm top border and 10 mm left/right border and 12 mm in between DVD label spacing. I was be able to create custom paper size but not the page layout. ...
I have an Apple with OS X Lion 10.7. Hooked up to a Pixma MX420. It worked perfectly up until about a month ago but something went south. Everything but the scanner works. Done everything I know to get it to work again short of a 10 pound hammer. A...
how to make my pixma ip 90 to work wireless with windows 7/64 i installed the bu-10 it is authorized but can't make it to print wireless.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
