I have a MG5220 PRINT HEAD WARNING
I just got a message U052 "The type of print head is incorrect. Install the current print head"I just printing something last night.Thank you
I have a PC on which I instaled the Canon drivers direct from Canon and I like the ScanGear interface a lot. It surved the upgrade from Windows 7 to 10 Professional. On the other hand, for my other PC in the home group, I just let windows install dri...
Hello, Regarding my: MG3122 printer/copier/scanner This device was working perfectly before I installed windows 10. After installing windows 10, I found that the printer and copier functions still work, but the system cannot recognize the scanner. Ac...
I have attemted to contact Cannon, no response. I have scowered the form to no avail, I have dug deep into the internet and found nothing. Does any have a clue, an insight, an understanding as to why Canon has droped support for the Mac OS 10.x and ...
How do you set a Canon Pixma MP280 All-in-One Photo Printer , to mirror image for shirt transfers ? Im really having hard time so any help needed .
I cannot install my cannon printer either with a Usb cable hooked up or wirelesly The error message is that the print spooler is not running. It claims the print spooler can't br found or is missing. I never heard of such a problem Could some pleas...
I have a pixma mg5220 all in one printer. Error code 5012 shows and a loud sound occurs. Running windows8.1 on hp smarttouch 15 812, MIGHT BE b12 It's hard to read. This happens rarely, but when it does, I don't know when it will start to work again...
I am now experiencing aproximately the same issues that MG5320 owners are experiencing, Everything is great, working fine printer and yoU run out of ink. So you run down t your locaL big box store (WALMART, Target, Office Depot, Staples) and you bu...
I am trying to print to the Disk Tray. I put the tray in but the printer does not recognize it. I try to select the tray as an option in my print settings but there is no tray option there to select (Photoshop, MS Word, PDF, etc). When I look to...
Mx310- worked fine till now.When I select print from File on computer I get a block displayed that requests the info to send a fax.Any help as to what might have gotten changed somehow.Thanks.
I'm having trouble making copies on my canon pixma MG 3220 i need help immediately thank you. If there is anyone who can assist me I would really appreciate it.
Several weeks ago I had accidetnally found the settings, and now can not for the life of me find it. I want to make the default settings of the printer to only print in blue, so It only uses blue from the ink and will only print blue stuff. Its a mul...
Hi, I have a PIXMA 432 and when I print 4x6 photos the top portion of the photo gets cropped. I use a 4x6 and put it in the printer long ways and use fill print. I tried a couple of different options and with the options I get a white border which ...
I have just bought this to replace my old printer (MG3170). There is one very useful mode i always need - Print from last page.... I cannot find this mode on MG3570 , is there something i am missing ? Hope someone can help me out.Thanks.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
