02-18-2024 07:16 PM
there does not seem to be an easy and quick way to tell the printer which paper tray I want it to use
I have to open the printer dialoug box each time?
I also cannot find out how to put a short cut to printer status on my desktop
so, if there is an option there, I have not been able to access it
for a while I worked around that by pulling the bottom tray out
but today, the printer decided it would not go for that trick and refused to use the paper in the top tray
until I spend 20 minutes trying to find a setting for that
Canon, I understand the difficulty of keeping up with an ever changing array of printers and software, but links that don't actually address the problems they claim to address, are just a waste of time for your customers
03-01-2024 08:27 AM
Is your printer connected to a computer running Windows or MacOS?
03-02-2024 12:14 PM
windows 10
I found it, after reading and trying so many outdated and inaccurate info on canon and ms
I found where to make the selection
the weird thing is that how the printer chose to use a tray changed, I can load legal paper in the bottom tray and it would use it then it decided it had to use the top feed...
I would put paper in the top feed and it would use that, then it decided to tell me there was no paper in the top feed when there is paper there
now I know how to TELL it what tray to use
what I dislike is how much work that was and, canon is not responsible for microsoft hiding essential features
but, ease of use
results in customer loyalty
one of the reasons I chose another canon was thinking it would work in a similar way
next time, I will know better
thank you
