TS9520 connection with new laptop
ladyhawk21
i have purchased a new HP laptop W11,   and i cant get it to connect with the printer- even worked with CS and they cant get it to connect.
could use some ideas of what else to try - the printer works fine with my dell
4 REPLIES 4
ArthurJ
So we can best assist you, could you please let us know what Canon support advised you when you reached out to them. Did they say what the possible issue could be or what troubleshooting steps they took with you.
The more information you can provide, the easier it will be for us to try and narrow down the cause of this issue.
they had me go through various steps  - we made sure the printer was connected to the wifi
we walked through the setup process - but it stops on that last step and will not connect
i also uninstalled all firewall software
If the printer can connect to another computer then I would recommend reaching out to Microsoft. Even though you uninstalled all firewall software, there may be a security setting on your computer that is not allowing the printer and computer to communicate.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
ladyhawk21
W11 comes with a security program - i followed the directions to disable it-  still cant connect
Friends and Family
