03-04-2023 01:18 PM
Hello. Friend has a TS6050 (ok, old!) and has let all inks dry out EXCEPT the small black which he says has been working for a long time. 1. is it a bad idea to let any ink run out? 2. does this explain the error codes? 3. is the print head likely overheated?
Will a new print head and all new inks likely solve the problem OR are B203/B204 errors for different reasons? thanks
