02-11-2021 12:44 AM
Greetings
I keep getting the same error message but every thing is plugged in and working turning off and on does nothing.
Error 5200
Printer error has occurred.
Turn off printer and unplug it.
After a while, plug in the printer again and turn it back on.
If this does not solve the problem, contact your nearest Canon service center to request a repair.
I would appreciate any assistance.
George
02-18-2021 10:21 PM - edited 02-18-2021 10:22 PM
Solved the problem.
Took the printer back to the store and got a refund.
So simple.
George
02-11-2021 03:35 AM
Are you sure there isn't a paper jam? I came here and created an account to ask a the same question then decided to review the manual for my printer (a TR8520.) I had a very similar message but a different error code. Looking up the error code in the manual led me to pictures showing me how to clear a paper jam. I didn't see the paper in there the first time I looked, but after looking more closely and opening up the back, I did find and pulled out a jam. Would have been a lot easier if the error message just said "jam."
02-11-2021 04:45 AM
I don't think it has a jam as when It is turned on, after a few loud clicks, the printer shoots a blank page through the printer.
Another problem I think.
George
02-11-2021 03:51 PM - edited 02-11-2021 03:53 PM
Every thing, print page, preview properties are normal until I select "Print" Same resutl using WIFI or USB.
Error 5200
George
02-11-2021 04:03 PM
Hi, George!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
02-12-2021 09:50 AM - edited 02-12-2021 09:51 AM
Information on error 5200 can be found about 3/4 down on the following page:
Canon : PIXMA Manuals : TS3100 series : An Error Occurs
In addition to the steps below, I would recommend removing and reseating each cartridge
Then...
Turn off the device
Unplug from power
Wait 30 sec
Reconnect power and turn on
If the error persists, the printer will require service or replacement.
Solved the problem.
So simple.
George
