12-29-2020 07:40 AM
Hello,
maybe someone coud help 😞
I have a canon pixma ts 5150 printer (connects via bluetooth) and yesterday the firmware was updated. Since then the printer does not see any devices and cartridges (which are full).
We did reset but nothing helps.
The computer sees the printer but the printer does not respond to the print order.
Using Win 10.
Does anyone know how to fix this?
12-29-2020 09:23 AM
The only thing I can recommend after checking the user manual for your printer is to re-install the drivers and to run Canon's repair utility:
On your computer:
This was found on page 850 from this Canon User Manual link.
12-30-2020 09:43 AM
Thanks!
I finally got a reply from the helpdesk.
If anyone else had a similar problem:
reset the printer's network settings (settings> device settings> reset settings> reset all)
Manually connect printer with router (by setting button), select LAN network, turn on wifi, select wireless LAN, select other settings> select manual connection
When router will be found, enter the router password, after connecting you're going to the next step - assigning a permanent IP address:
device settings button > select general settings > select TCP / IP settings > select ipv4, confirm YES > choose IP address > choose manually select >confirm YES, select / confirm the displayed ip address, subnet mask and gateway.
The printer saw the phone, laptop had to be reset.
Now the only problem is that the printer does not see ink substitutes, but maybe I can handle it ![]()
