01-08-2025
10:29 PM
03:31 PM
Tiffany
My TS 3320 has stopped printing documents sent from my iPhone, iPad or Windows laptop. It still copies and will print the info sheet, which confirms it is still connected to our WiFi network. I’ve gone through all the troubleshooting steps to no avail. Suggestions?
01-08-2025 11:32 PM
Welcome to the forum!
So that the Community can help you better, let us know which version of Windows or macOS you are using? Is there an exact error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
01-09-2025 03:29 PM
The iPhone and iPad are OS18 and both get "no air printer not found" message. The laptop is Windows 11 and said there was a problem with the driver. I tried deleting and reinstalling the driver but that didn't work.
01-10-2025 11:30 AM
Hi SueB1,
First, let's disable IPv6 on your PIXMA TS3322.
On your TS3322, please repeatedly press the wrench and screwdriver button until 16 appears on the display.
Once it appears, please press the BLACK Start button 1 time.
After you have performed that, please turn your PIXMA TS3322 and iOS devices off.
Please go to your router and unplug the power cord. Wait 30 seconds or so and then reconnect the power cord to your router. When your Wi-Fi network is back online, please turn your iOS devices and TS3322 back on and attempt to print.
01-11-2025 07:34 PM
This helped. It did not allow me to print right away but it did at least finally recognize that the printer existed. That allowed me to redo set-up process and print.
01-13-2025 04:04 PM
Unfortunately, that only worked for a day. I had to go through the process again to get it to work again.
