TR4522 copies are very light.
toothpaste
Is there any way to make them darker?
Every printer I have owned in the past has the option to make copies lighter or darker.
Darius
Whiz
Hi toothpaste.
The Copy Intensity may be adjusted in the Copy Settings menu.  More information may be found at the following link:
https://ugp01.c-ij.com/ij/webmanual/Manual/All/TR4500%20series/EN/UG/ug-044.html
Note: if the Copy Intensity is set to Automatic, the Automatic Document Feeder on top of the printer will be disabled.
2 REPLIES 2
Darius
Whiz
Hi toothpaste.
@Darius wrote:
Hi toothpaste.
Worked really well, thank you.
