‎02-13-2019 12:27 PM
It takes about 80 seconds from the time I initiate a scan in MP Navigator EX from my PC to the time the scanning begins. This is a recent development. It was much faster prior to this. Less than 15 seconds. What could be causing this sudden slowdown? Running Windows 10.
‎02-18-2019 01:22 PM
Hi, Jbertke,
Everything looks good with the printers signal. Next, I recommend removing the printer/scanner driver and MP Navigator from the computer. Once they are are both removed, please restart the computer.
After the computer restarts, please click HERE to open the support page of the printer. You will want to install the MG6100 series MP Driver Ver. 1.05 and MP Navigator EX Ver. 4.03 which can be found by clicking the software tab.
Once everything is reinstalled, please attempt to scan again.
‎02-13-2019 12:35 PM
Hi, Jbertke!
So that the Community can help you better, we need to know exactly which Canon model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
‎02-13-2019 02:14 PM
Neglected to say that I'm using a wireless connection to a Pixma MG 6120 and running MP Navigator EX 4.0
‎02-15-2019 01:32 PM
Hi, Jbertke,
I recommend printing out the network settings of the printer. This will help narrow down if there is a signal strength issue that is causing the slow scans. Please click HERE and follow the steps to print the network settings. Once the network settings print, please let us know what the signal strength is.
‎02-15-2019 02:13 PM
ArthurJ,
Thanks for your reply. The report from the printout is 81% signal strength. The Canon IJ Network Tool reports 83% signal strength and 86% signal quality.
Jim B
Hi, Jbertke,
‎02-19-2019 11:32 AM
ArthurJ,
Thanks for your help. The reinstallation of the software did the trick. Scaning is faster than ever.
Jim B
