02-12-2024 09:41 AM
Recently my Canon G7020 printer has started to print very slowly. It is right next to the router so it is not having a problem picking up the Wifi signal.
I've had this printer for 3 years and I love it.
Do you have any suggestions that a low-tech person can follow to fix it?
02-12-2024 11:34 AM
Very recently my Canon G7020 printer has started to print very slowly. It is right next to the router so it is not having a problem picking up the WiFi signal.
I've tried rebooting the printer, running maintenance to clean it, turning off quiet mode
It is very frustrating
I would very much appreciate any assistanc.
Thank you
02-26-2024 09:15 AM
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon G7000 series and left click on Remove device. Repeat until all G7000's are removed from this window.
5. Click Close to close that window.
6. In the upper left corner, click on Control Panel (or the Back button).
7. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
8. Click once on "Canon G7000 series MP Drivers" and then click Uninstall at the top.
9. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
10. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
2. Click the Select button next to "G7000 series Driver setup package".
3. Click the Download button. The drivers will download.
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click win-g7000-1_3-n_mcd.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
Once the installation has completed, please attempt to print.
02-26-2024 09:26 AM
Does "started to print very slowly" mean the time that elapses between you pressing the print button and the printer starting to print, or the amount of time a print takes to complete once the job starts?
01-22-2025 12:01 AM
the printer wifi is the the problem, can't pickup signal and caused very slow data transfer to the printer.
my solution is to connect to the ethernet port on the left rear side of the printer. after connecting to the ethernet, you have to enable to the lan setting in the menu control, otherwise the lan is diabled.
