TR7520 can't scan through ADF
turboglide
I have a TR7520 that can't scan through ADF. It worked fine up till now. It feeds the document almost completely through then stops and spits out a blank paper from the bottom tray. I can copy and scan through the glass scanner if I load it manually.
2 REPLIES 2
Patrick
Hi turboglide,
Please make sure that you are placing the original face up in the document feeder and following these steps:
https://ij.manual.canon/ij/webmanual/Manual/All/TR7500%20series/EN/UG/ug_l_03_03_c.html
Next, please load plain paper into the cassette of your TR7520 and then follow the steps:
1.  Press the Home button on your PIXMA TR7520 one time.
4.  Tap Print nozzle check pattern.
5.  Tap Yes.
Once that test page prints, please take a photo of it and then please reply to this post with that image attached.
turboglide
