Selphy 900 Multiple photos
ni2529
Is there a way to arrange photos to print using Selphy 900? I wanna print 4 pictures in one paper.
3 REPLIES 3
Karl1
Rising Star
Hi nl2529,
To print multiple pictuers on a single page, you first have to select which pictures to print, then you can choose the layout.  Scroll through the pictures using the left or right arrow keys, then use the up or down arrow keys to select the number of copies you want of each picture.  For example, if you have a picture selected and press up 4 times it will print that image 4 times.  If you press the up arrow once on 4 seperate photos it will print each photo once.
After selecting the number of copies, press the Settings button, then press the up or down arrow to select Change settings.  On the Change Settings screen, press the down arrow to highlight Page Layout, then use the left or right arrows to cycle through the layouts until you find the one you want to use..  Once you are done you can press the Back button to return to the image and tell it to print.
Thanks, Mr Cannon.
One more thing - Is positioning the images possible for multiple photos?
Hello nl2529.
If you are trimming the image or selecting a certain area, you may have to print the items one at a time.
If you need additional assistance, feel free to call us at 1-800-OKCANON.
