06-26-2018 07:55 PM
Can anyone help? I have an MX532 that makes awful scans. I don't understand it. I have had a Canon MG8120 that made beautiful scans. Here is a sample of a photo scan from the MX532.
06-27-2018 01:40 PM
Hi dbe1,
Please try uinsg the Advanced Mode of the scanner driver. To do this, please follow these steps:
1. Open the IJ Scan Utility. If you are on a Mac, this will be located in the Applications / Canon utilities folder. If you are using Windows, please click the Windows Start button (and then All Programs with Windows 7) and then the Canon Utilities folder.
2. Click the Scangear button.
3. Click the Advanced mode tab in the upper right hand corner.
4. Next to Select Source, choose Platen. Next to Color Mode choose Color. Select 300 DPI.
5. Click Preview at the bottom.
6. Make any necessary adjustments and then click Scan.
For more information regarding the IJ Scan Utility, please use the following link:
http://ugp01.c-ij.com/ij/webmanual/ScanUtility/W/MX530%20series/1.1/EN/SU/Top.html
For rmore information regarding Advanced Mode, please use this link:
http://ugp01.c-ij.com/ij/webmanual/ScanGear/W/MFP/20.0/EN/SG/sg-904.html
06-27-2018 04:28 PM
Thanks, but no improvement.
06-27-2018 05:06 PM
Hi dbe1,
In order to clarify the issue a little further, allow me to ask a couple questions:
I look forward to your reply.
06-28-2018 09:20 AM
I am using Windows 10. B&W text copies fine. Color photos look like the scans.
FYI - I also get a frequent error code 5011, which requires unpluggin and replugging the device.
Thanks.
06-29-2018 10:17 AM
Hello.
Troubleshooting with our support group will be needed to narrow down the causes of your issues. Please contact our support group using the "Contact Us" link below for additional assistance.
