09-29-2020 08:32 PM
I have a PIXMA ip7260 and have been trying to print on a CD. I have found that when the process is finished the image on the CD is not centered and most of the image is not on the disc. I have had several earlier versions of the printer and have always been able to print successfully. It is something I do only rarely so I am afraid that there is part of the process I have forgotten. I insert the CD attachment so that the arrow on the tray lines up with the arrow on the printer. Could it be the label printing software I am using> what is the best software to use?
10-19-2020 04:12 PM
Hi kafka,
Printing on discs can be off center if the correct disc is not selected in the software that you are using.
Pleas try using Easy-PhotoPrint Editor or My Image Garden to print on your discs. If you do not have these applications, they are available for download from here:
08-26-2021 12:21 PM
In case anyone else comes across this post and still needs help. Image Garden did not work for my Canon Printer no matter what I did or what instrructions that I fillowed. In the Pat I had used the Acoustica CD Label Maker, but with my TS9020 Printer it was not working. However, even though Acoustica said I had the newest version of their Software, I downloaded it atgain from their Web Site and it had some NEW Canon Priniters in its drop down list. I picked my TS90 20 and it worked perfectly just like in the past with my old Canon Printer. So make sure you download a current one from them beccause there IS some new stuff in it, even if their software check says that you do not need an update!!!
