05-26-2022 06:08 PM
Hello: I have a Canon TS 8320 printer, which has 2 paper trays. I was able to print from the cassette tray from my computer (MacBook Pro), but now it is only printing from the rear tray. Does anyone know how to do a reset on this?
I have done everything I can do with the settings on my computer, with no luck.
Thanks!
06-03-2022 02:53 PM
Hi patrick5,
The source the that paper is fed from is controlled in the Print settings. Please open an item to print.
Click on File and then Print.
Next, we need to see details. At the bottom, if you see "Show details", click it. If you see "Hide details", go to next step.
Once we are in the details view, click the drop down box in the middle of the page and select Media & Quailty.
Choose your desired paper source from the "Feed from" drop down box; Main tray or Rear tray.
06-03-2022 02:53 PM
Hi patrick5,
06-24-2022 03:39 PM
My same problem happens from the copy mode - prints to rear only. The only selections in the menu are "auto" and "rear". There is no access to the rear do to printer location. How do I select front cassette? Did a firmware update eliminate the front option. Now the printer is "again" unusable. First time was the worthless paper detect/computer software issue. JUST LET THE PRINTERS PRINT!!!!!!!!!
02-03-2023 11:39 AM
This is great if you actually want to print from the rear tray, but if you want to print from the main tray there's no way to change the option. I've put my settings as print from auto and also tried print from main tray. Both settings still try to get my document to print from the rear tray. I get an error message from my printer every time. Why would the printer default to rear tray only?
02-24-2023 01:49 PM
Sorry, don't see an Accept as Solution button but this did work! Thank you!
09-14-2023 04:17 PM
The Selected Solution only works one way. Not for copies usnig the cassette. if you want to print from the cassette there's no way to change the option.
I am using to copy, not from my PC. The printer's front panel should allow me to press a button and make a copy, no?
The Canoon TR8620 is struggling to find paper. There is no reason whatsoever why I should not be able to print a simple black and white copy with the press of a button, maybe two.
The printer wants paper from the area where there is no paper and I am not given the option to choose the cassette or the printer is not smart enough to look in the other tray. I've put my settings as print from auto and also tried print from main tray. Both settings still try to get my document to print from the rear tray. I get an error message from my printer every time. Why would the printer default to rear tray only?
09-18-2023 02:14 PM
Please try the following:
10-14-2023 07:18 PM
Thank you Arthur J.!!
This actually worked! But this makes no sense! Totally NOT user friendly! This wasted a LOT of my time.
Whomever wrote the original software needs to try again! Write the settings properly.
Thank you again
06-06-2024 01:42 AM
Arthur J you are a genius. You probably saved me from buying a new printer after much frustration over this problem.
THANK YOU!
04-08-2025 12:47 PM
Hi
Unfortunately this didnt work for my TS6400 series. It has the enable/disable option for the mismatched paper, but it didn't work for me. What else can I do? my printer is only 8 months old.
