05-16-2021 04:43 PM
Im trying to do the instalation on my computer, at first he detect the printer and after like 5 minute a error printer connection, the printer is not detected....
05-17-2021 10:42 AM
I suggest using the latest installtion software from your printer and OS, found here:
Support | MG Series - Inkjet | PIXMA MG2920 (MG2900 Series) | Canon USA
Wireless Setup help here:
The printer will pnly connect to a 2.4Ghz broadcast. If you are using a dual or tri-band router 2.4/5G that usese the same SSID (network name) this can sometimes cause connection issues. Temporarily disabling the 5G broadcast while performing set up often helps.
3rd party anti-virus applications (if applicable in your case?) can also interfere with detection.
08-04-2024 02:02 AM
Printer NOT DETECTED for over a hundred times of installation, WHY CANON WHY?!!, why is is so difficult to install your driver? Its already 2024! My friend also bought a brand new Canon printer with the same problem. Thanks to your very complicated driver installer, 4 months already but they cannot use the printer for school use, so they just sold the Canon and now her problem is already solved...with another new set of printer from a different brand...smh!
