Printer Pixma MX922 keep getting message ink cartridge cannot be read. Tried 2 different ones .
cdsaccountant
PixmaMX922 cartridge not read.
Is printer done?
2 REPLIES 2
Patrick
Hi cdsaccountant,
Please follow these steps to try to resolve this issue:
1. Confirm that the printer is powered on.
2. Pull open the paper output tray.
3. Lift the scanning unit (printer cover) completely. The print head will move to the replacement position.
4. Open the inner cover.
5. Remove the ink tanks by pressing the tab of each tank.
6. Raise the print head lock lever.
7. Tilt the print head slightly towards the front of the machine and lift out gently.
8. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
9. Insert ink tanks into the print head.
10. Press the mark <PUSH> on the ink tank firmly until you hear a click.
11. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
12. Close the inner cover and the scanning unit/printer cover.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Won't print with replaced ink cartridges. Status indicates “Ink details cannot be displayed” on PC and showing error in printing queue. However, copy can still work and display ink level on MX922's LCD panel. Tried power cycle and re-install ink cartridges several times with same result. Please advise, thanks.
