09-02-2013 09:24 PM - edited 09-02-2013 09:43 PM
Hello! How do you print a document from the manual top feed of a Canon MG6120? Not a photo - I've printed those from the top before, but simply a document (I'm making invitations). I'm sure there is a simple way to do this but I'm flummoxed! I would appreciate any help/direction!!!
09-15-2013 11:09 AM
Hi SMDobransky,
Fortunately, it is simple! When the printer detects that something will be printed on plain paper, it will pull paper from its plain paper feed source. With this printer, you can change this source to either the cassette or the rear tray. Follow these steps:
And that's it! You should be all set. Keep in mind, you will need to change this setting back to Cassette if you wish to switch back to the front tray feed.
One final thing. Since I see you are printing invitations, be sure to select the paper type in your printing application. If you are using cardstock, for example, select cardstock instead of plain paper in your print settings to ensure great quality results. Paper types other then plain standard size paper will always feed from the rear tray.
If you have any other questions, please feel free to Contact Us!
