04-12-2026
10:54 AM
10:56 AM
James_C
My ts64-208 printer is giving me an error code 7700 it says that I've either replaced the paper when it was off or something like that one time and then the other time it just goes straight to the error code.
04-12-2026 11:00 AM - edited 04-12-2026 11:05 AM
I want to add to what I posted below, if your ink cartridges are not made by Canon, they could be the source of this problem.
Understanding Error Code 7700
The error code 7700 on the PIXMA TS6420a printer usually signifies a problem with the print head or an internal hardware malfunction. This can stem from several issues, including:
To troubleshoot and potentially fix the error, follow these steps:
If the error persists after trying the above steps, it may indicate a more serious internal issue. In this case, it is advisable to:
