01-31-2025 10:28 AM
Initially the printer was only printing color and not black so I replaced the ink cartridges and cleaned the ink head. Now the printer is only printing black. Any suggestions on how to fix this issue?
01-31-2025 02:11 PM
If you run a nozzle check and several deep cleanings and you still aren't getting all colors to print then you most likely have a clogged/failed print head. If you tried one of the methods described on YouTube and still have no luck you probably need to replace the print head.
