03-25-2021 01:52 PM
Hello - i just purchased a Canon Pixma TS6420 printer and set it up wirelessly since it does not come with a USB cable.
The printer function is working fine after the normal driver install, but the scanner will not recognize. I have tried finding it in the Canon Scan Utility Lite software, as well as the Mac's Image Capture program.
The Scanner shows up in Image Capture, but errors out "cannot communicate with scanner".
I am using Mac, ios Mojave.
04-19-2021 02:54 PM
Hi kellbell88,
When you scan with Image Capture, what error code appears at the bottom of the error message that you get?
03-27-2022 10:49 PM
I have the same problem. When I try to scan using Image Capture, I get the message: An error occurred while communicating with the scanner. (-9923)
While trying with the IJ Scan Lite, the window asks to check the connections, either USB or wireless. I'm connected wirelessly and have no obstructions.
I have no problem printing, from a variety of applications. Just like kellbell88, I'm using a Mac, iMac and OS Mojave, 10.14.
04-01-2022 02:45 PM - edited 04-01-2022 02:46 PM
I had this exact issue today. I could print from two different Mac laptops but could not find the TS6420 as a scanner. I could scan to my android phone without issue. I used the chat function and we tried a bunch of things and finally got it working. Not sure if this would be the answer for you, but for my home network we needed to disable IPv6 to get scanning to work with my Mac. Here is a link to the steps to do this on the printer. Hopefully this helps!!!
https://support.usa.canon.com/kb/index?page=content&id=ART180256
Kelly
