04-10-2022 08:33 AM
After getting message 1700 "Ink absorber is almost full" I was able to remove and clean the ink absorbing pads and reset the counter. The message no longer displays. However, is there a larger ink absorbing unit beneath these pads, that once full, the printer will no longer function? And if so, how long between this initial warning code and failure to print? I realize that may depend on print volume but a ballpark figure say 100 pages, 1000 pages? Last, if there is a waste ink reservoir, can I replace it?
01-07-2023 04:43 PM
You say " I was able to remove and clean the ink absorbing pads and reset the counter. The message no longer displays." Please advise how. I have a Pixma G4210 and I want to replace before I get dreaded 5B00 message.
01-07-2023 05:17 PM
I do not recollect; I searched for how to clean the pads and reset the warning message and found some videos on YouTube. However, that proved to be a temporary fix as the message eventually reappeared, and although I performed the same cleaning and resetting procedure as before, the printer did not respond this time. Again, I don't exactly remember, but maybe I got another month of use out of the printer, but had to replace it in the end. I may be wrong but I think the pads I was able to access were simply small ink absorbers where the print heads rested and underneath was a much larger ink pad that could not be accessed without disassembling the printer. (I made an attempt but failed) When that larger pad became full the printer was bricked.
09-04-2023 09:24 PM
Hi Geajrpa, I had the same problem with mine today actually it started a few days ago but today it got to the point where it wasn't even letting the scanner work for some reason and the code would come up whenever I went to preview so I don't know why anything having to do with the printer should effect the scanner but evidently it did. So then I was reading through the in one guy said that and I think it was actually a rep from cannon said that when you get that. Toad you've got a change the color cartridge and then so ICunnup come up when I will try to do a preview around that just. Then I did some research and it said. Then if I didn't have AI need a replace that color my tank.
It's like make it worse. I don't know why I didn't mean that for the scanner but that's what it said so I was on my way over to go and get. One? When Found a post here but the CANDIdate community were somebody had gotten some tissue and wiped off the.
Make. Absorbs over and that held to to work for a while so. What that in mind? I decided to pull out my incorporates and look below where they're read and I think of the incomes for plate right below
Which? Is below or the paper lays and above the pink absorber ripe below the incarceration? And I. Look at a closely and there is all this dried up ink on This plate Which has is evenly raised ridges on it and is the width of A shoot of paper which is the rhythm machine of paper and is ripe below where the a kids the inca cartridges print the paper. There was all these ink stains on it the whole width of it. Which? Was I guess where it was absorbing the equine was So I decided that it needed to be clean so I could come to my broken. Feed the global alcohol and education and I really cleaned the heck out of that plate. I put the ink cartridges back in which we would have to reset metabolism evidence for a while. I think I even feel one of them And then I went to word and I went to maintenance and I printed A test pattern finally and now I also notice that that flashing light had gone off so I went back to my scan gear app.
And I opened it and this scanner now is working so I didn't need to and I try it before. I had tried pushing the power button Monday resume button at the same time and holding it down is waiting 5 seconds all that but none of those work Anyway I hope this Helps god bless!
