07-29-2026
02:56 PM
03:04 PM
Tiffany
Error message on printer "Ink absorber almost full"
How do I resolve? When printing pages do not come out clearly
07-29-2026 10:11 PM
This error indicates your printer will need factory service soon or will need to be replaced.
Press the RESUME/CANCEL button to clear the error (1700) https://share.google/wwEChpFOFmieNmMPU
You cannot bypass this error indefinitely. Eventually the printer will need to be serviced or replaced.
07-30-2026 08:58 AM
Error code 1700 on your PIXMA TS8220 indicates that the ink absorber is almost full. This is a common maintenance issue in Canon printers, particularly after extended use.
The error typically arises due to:
To resolve the error, you may need to clean or replace the ink absorber pads. Here’s how:
Locate the Ink Absorber Pads: Open the cartridge compartment to find the pads beneath the cartridge assembly.
Remove the Pads: Carefully take out the pads, which may contain waste ink.
Clean the Pads: Rinse the pads in warm water until the water runs mostly clear. This may require several rinses.
Dry the Pads: Allow the pads to dry completely, which can take several hours.
Reinstall the Pads: Once dry, place the pads back into the printer.
Reset the Printer: Turn the printer back on and check if the error persists.
If the error continues after cleaning, it may be necessary to contact a Canon service center for further assistance or to replace the ink absorber pads.
07-29-2026 10:11 PM
07-30-2026 08:58 AM
