Pixma TR8620a Duplex Printing Issues
DrTek
Hello all!
I am running Windows 10. Printer is #PixmaTR8620a.
My printer has suddenly changed it's double-sided printing options.
It used to print both sides of the paper from the bottom cassette, i.e. print one side of the paper, then draw it back in, and then print on the reverse side.
Now it requires me to place the one-sided printed page in the rear feed slot to print on the reverse side.
I have turned off duplex printing in the properties window, but I still need to print on both sides of the paper at times, multiple copies for educational handouts.
I have reset printing options from the user interface window, however, this issue still continues.
Many thanks for your assistance with this issue.
Kind regards,
DrTek
That link should uninstall & reinstall everything automatically. 😊
7 REPLIES 7
Stephen
Moderator
Moderator
Hi, DrTek!
I'm not a tech, but I've seen things like this happen when the incorrect drivers are being used (perhaps a Windows Update did something). Try to reinstall the software from https://canon.us/TR8620aSetup. If it's a driver issue, it should solve the problem. Let us know how it goes!
DrTek
Thank you, Stephen.
I had already installed the newest drivers versions from Canon, however, I will give your instructions a try to set up from the beginning.
Thank you, Stephen!
Your solution seems to have repaired the problem: I am able to print on both sides of the paper from the bottom cassette! YAY!
Awesome! I’m so glad I could help!
Hi Stephen, I have the same problem and tried the re-installation but it is still wanting to give me only one page and reinsert for the back side. That is not feasible with a print job of 118 pages. Do  you have any other suggestion as to how to fix this problem? Thank you!
Patrick
Hi Val1,
What version of Windows are you using on your computer?
If you are using a Mac, what version of the macOS is installed?
What program on your computer are you using to print your document?
