03-12-2019 04:29 PM
I just got this printer and when trying to copy, it will only print from the rear paper. How can I make it print from the cassette when copying?
03-15-2019 01:24 PM
Hi oldg,
You can set the printer to use the cassette. When you have the copy menu on the printer screen, press settings (C) in the picture below:
From the settings menu, swipe down until you see Paper scrc. It should be set to Auto. Tap on it and change it to Cassette. The printer will now pull paper from the cassette when making copies.
03-15-2019 01:24 PM
Hi oldg,
03-15-2019 01:47 PM
This answer resolved my question. Thanks.
