07-10-2020 06:49 PM - edited 07-12-2020 09:49 AM
When I try to print a letter size pagefrom te lower tray, it tells me that the form size is wrong for the Hagaki 2 (upper tray - photo print/envelope tray). I have checked everywhere and they are all Letter/Lower size paper. I uninstalled and reinstalled the drivers. I unplugged and replugged the printer. I tried printing without duplex printing. I tried only printing a single page. I anually deleted all the programs and removed the Canon Registry Entries and reinstalled the drivers with the same result.. The only place that a letter size page can be printed is with the Print Test Page button in the Properties window for the printer on the Device Manager. I can print to the lower tray from smartphones and tablets so it's sometihing in my laptop. How do I get rid of Hagaki 2!
07-16-2020 04:18 PM
Thanks for your reply. I tested with many other programs and they were fine. The problem is in Adobe Acrobat and only with certain files. There must be something in the file that's causing the problem. Problem solved. Thank you.
07-16-2020 03:33 PM
Hello.
Please make sure that the paper size is set to Letter and that the Media Type is set to plain paper before printing from your software.
If the error persists, tell us what version of Windows or Mac OSX is on your computer. Also, tell us if this occurs when you print from any program on the computer, or only when you print from certain programs.
07-16-2020 04:18 PM
