05-04-2014 03:02 PM
My Pixma MX892, which I would guess is a little over a year old, has suddenly stopped working. I was able to print just two days ago, but now the unit will not turn on at all. Yes it is plugged in and yes the cord is connected to the unit. It simply won't start no matter how many times the power button is pushed or how long it is held down. Is this a known issue and what might be a way to fix this problem?
06-04-2014 08:50 AM
Hi Mortypie, turnem and ticarre:
Please follow these steps to try and resolve the issue:
1. Unplug the power cord from the back of the printer and from the wall outlet/surge protector and leave them out for at least 10 minutes, then plug it back in. Sometimes one port on a surge protector will work, while another will not, so we recommend plugging the printer directly into a wall outlet.
2. If the printer reset didn't work, please try to plug the printer into another power outlet in a different area of the room, or another room if possible and try to turn the unit on.
3. If you have another power cord you can use with the printer, please try to use that power cord to see if this will power the unit on.
If the printer still does not turn on after these steps, it will require servicing to resolve the issue. Please call or email us at one of the methods on the Contact Us page to obtain your servicing options.
01-14-2015 09:24 PM
01-16-2015 08:03 AM - edited 01-16-2015 08:04 AM
@gdelprete wrote:I experienced the same problem with a dead pixma. I called cannon and explained the problem and though they didnt resolve the issue in this call, I explained I was not satisfied with the help I received in the call and the issue was not resolved and they called me and have resolved the issue.Printer is working great now. Thanks cannon for your help with this. I've gone from sour to sweet.
gdelprete,
It sure would be nice if you could share your fix with the group. It's kinda why we're all here.
01-16-2015 08:10 PM
For Ultramagnetic74 and gdelprete -
Thanks for your input.
I think if you did a survey of all the customers on this thread, you would find that
almost all of them did the "unplug it, wait ten minutes, plug back in and press
power on button five times (or was it ten times?)" suggestion from the customer
support at Canon. And I think almost to a person, it didn't work. Neither did moving
it to a different outlet, or opening the case and tickling it's fancy.
Ultramagnetic74, if it worked for you, buy lottery tickets - lots of them.
gdelprete, I'm glade you got your printer working. I have a few questions, like
most of the people on this thread - first, what did they have you do?
Maybe they have come up with a different fix from the ones they told me when
I first called. Let us all know, and we'll all give it a try.
Second, is your printer still working?
As you can read in my first (?) post here, my printer did all kinds of things when
I tried their suggestions, except print (or scan, or fax).
So, please, let us know what you did.
Thanks
-B
01-21-2015 06:06 PM
Hmmmmm another one of my posts have been deleted.
01-21-2015 08:22 PM
@bnio wrote:Hmmmmm another one of my posts have been deleted.
Um, I'm too scared to write anything the least bit negative. If I do I'll be banned again for 9996 mins which =167 hours which = ~ one week........6.9 days. Canon? Why are you so mean!
01-22-2015 08:16 PM
Has anyone heard back from gdelprete or ultramagnetic74?
I would like to try these fixes, but if no one's telling, it's hard to try.
BNIO - sorry to hear about your posts. Maybe you should try posting again?
I know I would like to hear your opinion.
-B
01-25-2015 04:12 PM
01-25-2015 10:08 PM
Thank you Ultramagnetic74.
I'm a guessen what ever the problem was with your printer must have
been different than what is happening to others.
Good luck with your printer. Please let us know if you have any problems again
i.e: it stops working, etc..
-B
01-31-2015 03:04 AM
Wow.. add me to the list. 19 months old PIXMA892... stopped working suddenly. And won't power on. Canon, you are ruining your image by not doing something meaningful about this issue.
02-02-2015 07:59 PM
Hi Canon Support
My PIXMA MX892 just stop working, I tried everything to do in order to see if it would turn on, but no luck. I changed the location of the printer and still no luck.
The printer would beep and a couple of secs of screen pop-up and thats it. I hit the "ON" button but no luck.
I even tried to reinstall the software but no luck there.
What is the solution that Canon is providing for this printer, this is not even a year old printer and I barely use it.
Now this is furstrating...for a quality company to have a printer problem like this.
Thanks
