07-25-2021 10:20 AM
I removed the wireless printer from my laptop because it kept going offline. When I tried to reinstall the driver I got so far as connecting the printer butit wasn't successful. I then went back to the beginning but after I said "yes" to making changes to the computer I got the following message:
Win Zip Extractor
Can't create output file
c:users\naomi\appData\Local\Temp\Win-mg36001-0-JUCDmsetup4.exe
Can anyone tell me what that means and how I can get past it to try to install the driver?
09-14-2021 04:01 PM
Hello Nlw,
The can't create output file will point to security blocking the install or it means there is already an instance of the setup running on the computer. In that situation, you can try opening your task manager to check if any instance of the setup is running or you can restart your computer. If you continue to have the issue, you can also try turning of any security software that is running.
To see if there are any other options we can give you, please reply to this message with the specific version of Windows that you have.
