Chromebook app crashes [PRINT Inkjet/selphy] trying to print to G3260
tupjohn
I installed the software on my Windows machine and successfully printed
I also installed the Print Inkjet/selphy app on my android phone and printed successfully.
After installing the app on my chromebook it crashes every time I try to run it.  I have uninstalled and re-installed multiple times, cleared cache, given all permissions, restarted multiple times.  All without success.
Hector
Hello Tupjohn,
The Canon Print inkjet/selphy app was designed for use with Android or iOS devices and is not compatible with the Chrome OS. If you have a Chromebook, you can connect it using the steps below on your Chromebook.
  • At the bottom right, select the time.
  • Select Settings .
  • At the bottom, select Advanced.
  • Under "Printing," select Printers.
  • Next to "Add printer," select Add printer .
Enter your printer information:Name: Enter any name.Address: Enter your printer’s IP address.Protocol: For most printers, the supported connection protocol is IPP.Queue: For most printers, the queue is ipp/print.
  • Select Add.
If you do not have the IP address, you can print the network settings using the steps in the link HERE.
1 REPLY 1
Hector
Hello Tupjohn,
  • Select Settings .
  • Select Add.
Friends and Family
