07-26-2015 04:13 PM
Recently I have been unable to shutdown printer. Have pressed buttons but get message that it is shutting down and to wait. After 12 hours, printer still has same message. I cut power to unit and repower up and it restarts but tells me not to kill power unless I use proper shutdon procedures. I updated firmware to 2.010 but still have same problem. I have had the printer for 1.5 years or so and this started recently.
07-27-2015 07:08 PM
07-27-2015 10:09 PM
It is plugged into a power strip and has been for over 9 months with no problem. This started recently.
07-28-2015 11:18 AM
07-28-2015 06:50 PM
Could not reach the wall outlet but did remove some items plugged into the strip and tried it. It shutdown OK. Will see if it does so when I close down my computer tonight. If not then that was the problem. If it does act up then I will be back.
Thanks
07-28-2015 08:16 PM
