12-01-2022 06:01 AM
I have a user that has Canon LIDE220 on dell PC with win11...Randomly user is experiencing window with confirmation of shutting down windows (than he needs to click on no to continue work) , although user didnt clicked anything and is working on a pc..It looks like somehow scaner is sending signal to shutdown windows...The same thing happened when i delivered another pc to user, and installed same scaner on that new PC..The same window pop-up was randomly showed on a new pc...Is there any option for that scanner that can send shutdown signal to windows?
12-01-2022 08:11 AM
Hi, hreich!
So that the Community can help you better, we need to know exactly which applications you're using with your Canon scanner. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-01-2022
08:53 AM
09:46 AM
On customer PC it was this version: CanoScan LiDE 220 Scanner Driver Ver.1.04 (Windows)
12-02-2022 12:25 PM
Hi hreich,
Because this issue occurs with 2 separate computers, I doubt it's the computer or computer settings causing the computer to turn off.
Please try using a different USB cable.
If the issue persists even with a different USB cable, the CanoScan LiDE 220 would require service.
If that is the case, please contact our support group using the following link:
https://mycanon.usa.canon.com
They will provide you with your available service options.
