12-29-2023
11:02 PM
03:45 PM
Stephen
Received a Pixma IP8720 for Christmas. In the past I’ve used several wide format printers and have missed the ability to print something larger than letter or tabloid size, especially since I love landscape photography. The IP7820 seemed like a reasonable purchase to see the viability of having an in between sized printer. Tonight I printed my first six photos on some semigloss paper I had on hand. At first I was quite impressed, but two events slightly dotted my excitement. The first was seeing in my print queue that the cartridges were at 60% capacity after 6 letter size prints. Yes, I did print them at max resolution but still… Secondly on print had a couple of drops of water on the print which ruined the photo. So two questions:
1. Does this printer eat ink or are these starter cartridges?
2. Will the IP7820 give me water proof, fade proof archival quality prints or not?
Thanks
01-06-2024 07:38 PM
@Cwmn wrote:You're correct. I have a Pixma IP 8720. So all the questions should be about the 8720
The ip8720 uses ChromaLife 1oo+ inks.
From the Canon site for the printer:
"ChromaLife100+: This system combines enhanced FINE print head technology with select genuine Canon photo papers and inks for beautiful borderless photos that will last up to 300 years when stored in an archival-quality photo album.7"
These are dye inks and are not water resistant.
This article will give you some facts on the printer: Canon Pixma iP8720 Review (redrivercatalog.com)
01-06-2024 09:14 PM
I don’t know for your printer specifically, but none of the several (8 or more) Canon printers I have purchased ever had cartridges marked Starter.
The initial startup does require purging of the feed and print head which does consume ink.
12-31-2023 03:14 PM
Thanks for joining the conversation, Cwmn!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. I fear you might have made a typo (we do not manufacture a printer with the model number of ip7820, mabye ip8720 or ip7720 is your model number?). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-31-2023 03:43 PM
01-06-2024 06:07 PM
I’m not sure if I replied to you last time or not. But my new printer is a Pixma IP8720, thanks for catching and pointing out the error. Now perhaps I can get a reply?
01-06-2024 07:16 PM
You answered your own question about waterproofness. If you had water spots, obviously the print isn't waterproof.
Archival quality is mostly dependent on the paper being acid-free. The paper manufacturer could tell you that.
Canon could, possibly, tell you about fade resistance. That depends on how the prints are displayed/stored.
01-06-2024 07:38 PM
01-06-2024 08:41 PM
Thanks for the answer and link!
Regards!
01-06-2024 08:48 PM
Any clue why after five 8.5x11 prints 3 cartridges are reporting 35% of the ink is used? Are these starter cartridges or ?
01-06-2024 09:14 PM
