12-17-2018 12:23 AM
12-17-2018 03:18 PM
Hi blackxacto,
In the Apple menu or the Dock, select System Preferences. Select Print & Fax, Print & Scan, or Printers & Scanners, select your product, and select Options & Supplies. Select Utility and select Open Printer Utility. Cleaning may be listed in the menu, click on cleaning and a drop down menu will appear. In that drop down menu, select Ink Level Information.
12-17-2018 08:43 AM
Hello!
So that the Community can help you better, we will need to know which version of macOS you're using as well as the way you connect to your printer (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE for support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
12-17-2018 02:16 PM
12-17-2018 03:18 PM
Hi blackxacto,
12-17-2018 03:22 PM
