04-23-2026
10:35 PM
08:53 AM
James_C
Hi, I was wondering if people knew how to clean the ink rollers of a pixma ix6820. Whenever I print, there seems to be an imprint of an old print job on the backside of the paper. I'm assuming its because the rollers are dirty and covered in ink. Any help is greatly appreciated!
04-24-2026 08:33 AM
Here is the guide to clean the rollers:
https://ij.manual.canon/ij/webmanual/PrinterDriver/W/iX6800%20series/1.0/EN/PPG/dg-c_roller.html
04-24-2026 11:26 AM
Hi I have done this procedure already and it seems this procedure is more for cleaning paper particles and if the paper is not being fed properly. I don’t have issues with the paper being fed nor paper particles, but if this procedure also works for ink smudges should I run it a couple of times more?
04-24-2026 02:11 PM
Hi Bu_bby,
Please try performing a bottom plate cleaning:
iX6800 series > Cleaning the Printer > Cleaning the Inside of the Printer (Bottom Plate Cleaning)
04-24-2026 04:52 PM
I don't think it would hurt. I also suggest purchasing some roller cleaning sheets from Amazon.
05-01-2026 02:15 AM
I’ve done the bottom plate cleaning and it doesn’t seem to work. Weirdly enough the print smudge mainly seems to appear when I print specifically on 4 by 6
05-01-2026 09:23 AM
Smudge marks on 4x6 printouts can be attributed to several factors. Here are the main causes:
To address and prevent smudge marks on your 4x6 printouts, consider the following solutions:
| Solution | Description |
| Use Appropriate Paper | Ensure the paper meets the printer's specifications for optimal results. |
| Check Margin Settings | Set appropriate margins in the printer driver to avoid edge smudging. |
