PIXMA TS6420a cartridge issue, support Code 7700
Dscheible
I’m getting support code 7700, when I open the top of my printer, my ink cartridges are not sliding over automatically, but I can manually pull them over. How can I fix the automatic sliding? I imagine that is linked to my support code.
1 REPLY 1
DerrickL
Repairing PIXMA TS6420a Support Code 7700
Common Causes of Error Code 7700
The support code 7700 on the PIXMA TS6420a typically arises from:
  • Damaged Contacts: Often more than not due to using third-party or refilled ink cartridges.
  • Cartridge Issues: This error can occur after replacing cartridges or when the ink has run out.
  • A cartridge may not be seated properly in its slot. Remove and reinstall it. Make sure it locks into place.
Steps to Repair Error Code 7700
  1. Replace Ink Cartridges:
    • Remove the current ink cartridges.
    • Install genuine Canon cartridges to ensure compatibility and proper function.
  2. Check Cartridge Installation:
    • Ensure that the cartridges are seated correctly in their slots.
    • Verify that there are no obstructions or debris in the cartridge area.
  3. Power Cycle the Printer:
    • Turn off the printer and unplug it from the power source.
    • Wait for about 10 seconds, then plug it back in and turn it on.
