12-01-2024
11:49 AM
11:49 AM
SamanthaW
TS6420a
Printer has worked fine for a year. I have never used rear paper feed. I wanted to print a picture, so I put a sheet of photo paper in the rear feed. It printed the photo fine.
Now the printer will not print from the front cassette. Preferences are set to plain paper and letter. I have tried, automatically select paper feed, and also selected cassette. Error is USB001 A paper size that cannot be fed from the cassette was selected. USB002 Change paper source to rear tray, load paper, then print again.
It will print a test page from the cassette. It will make a copy from the cassette. It will not print anything else from the cassette.
I tried deleting and reinstalling printer.
12-04-2024 04:54 PM
Hi CPM,
What version of Windows is installed on your computer?
If you are using a Mac, what version of the macOS is installed?
12-05-2024 07:10 AM
Windows 10
12-10-2024 02:48 PM
Hi CPM,
Please turn your PIXMA TS6420a on and then follow these steps:
1. Press the OK button on your TS6420a one time.
2. Use the down arrow to select Feed settings and press OK.
3. Use the down arrow to select Cassette paper settings and press OK.
4. Press OK again.
5. Use the down arrow to select Change and press OK.
6. Select Letter and press OK.
7. Select OK and then press OK.
8. Use the down arrow to select Detect paper setting mismatch and press OK.
9. Select Disable and press OK.
Once set, please attempt to print.
If the error persists, next, we will reinstall the driver.
Are you using your TS6420a wirelessly? or with a USB cable?
12-11-2024 01:45 PM
Using USB cable.
I followed the instructions. Did not print.
Support code 1000
Load paper into rear tray correctly and press OK
It doesn't want to use the cassette.
12-11-2024 02:24 PM
Hi CPM,
On your computer, please press the Windows key on your keyboard and the letter R, then let both go.
In the Run window that appears, please type NOTEPAD and click OK.
Type out a few words.
Click on File and Print.
Make sure that letter and plain paper are select and click Print.
Are you able to print from Notepad?
12-11-2024 05:43 PM
It will not print from notepad.
(A paper size that cannot be fed from the cassette was selected. Change paper source to rear and load paper.)
Preferences are set to letter 8.5 x 11, plain paper, and cassette.
If I remove all of the paper from the cassette, I don't get an out of paper warning.
I just tried making a copy again. It will print a copy from the cassette just fine. If I remove paper from the cassette and try to make a copy, then it will say out of paper.
