PIXMA TS6420a: Error code 7700
plainjanea
I HAVE A CANON TS6400 REPLACED THE INK WITH THE PROPER 260 REPLACEMENT AND I'M GETTING THE CODE OF DEATH 7700 HOW DO I FIX THIS?  HELP
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, plainjanea!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TS6400 series.  The model number should be on the front of the unit at the lower right. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
TS6420a
DerrickL
If you just replaced the printer cartridges, make sure all the contact protection tape is removed, and then reseat the cartridges. You may need to power down the printer and restart it after a minute. Just curious did you replace the color cartridge as well?
