11-14-2024
09:22 AM
09:24 AM
I just purchased a new TS6420 printer. With my old printer, I could put a 8 1/2 x 5 1/2 sheet of paper in the top feeder and it would print perfectly fine. With this printer you have to insert it in a tray and it jams every time, how do I print an 8 1/2 x 5 1/2
11-14-2024 10:01 AM
Doesn't the printer have a rear feed tray? That is usually where custom paper sizes go.
11-15-2024 06:40 PM
Thank you. I did put the paper in the rear feeder but now I can’t figure out how to make the printer use that paper. I remove the regular size paper from the bottom tray and that didn’t work either.
11-15-2024 07:12 PM
What app are you trying to print from?
11-15-2024 08:18 PM
I have an Apple Mac desktop computer that I’m trying to print from.
11-15-2024 09:44 PM
But what software and what are you trying to print?
11-17-2024 01:04 PM
I am trying to print a mailing label out of eBay. I’m not sure what else I need to tell you. With my old printer, I could just put half a sheet of paper in the feeder and then it would just print.
11-17-2024 01:51 PM
When you press “print” does any window open where you can make selections?
11-17-2024 02:09 PM
So just use an 8.5 x 11 sheet to print the label. What's the real problem here?
11-17-2024 02:13 PM
Hello.
To utilize the full capabilities of your printer, you will need to install the Canon software and drivers instead of relying on AirPrint. You can get what you need from https://canon.us/TS6420Setup
You can find the various media sizes your printer accepts HERE.
There is a note below that section:
Special sizes
Special page sizes must be within the following limits:
rear tray
Maximum size: 8.50 x 26.61 in. (215.9 x 676.0 mm)
cassette
Minimum size: 5.83 x 8.27 in. (148.0 x 210.0 mm)
Maximum size: 8.50 x 11.69 in. (215.9 x 297.0 mm)
