03-25-2026
01:51 PM
03:02 PM
James_C
Using Windows 11 and until a few days ago I was able to print crossword puzzles from newspapers. Then, all of a sudden, I can't print crosswords. I replaced all print cartridges with genuine Canon cartridges, ran the clean print heads utility, including the deep clean, and still cannot print puzzles. Text prints well. Any suggestions would be appreciated. Thanks.
03-25-2026 02:08 PM
Hi there!
Thanks for posting to the Canon Community!
Can you please go into a bit more detail about the print issue with your PIXMA TS6120? When you say you can't print do you mean it comes out blank, blurry, etc... ? As much detail as you can provide will help the community better help you.
Thanks so much!
03-26-2026 08:25 AM
When I try to print a crossword puzzle (as I had done on an almost daily basis) the printer prints out a blank sheet. To my surprise, I can still print out Sudoku puzzles. I can print text.
03-26-2026 08:42 AM
Hello jac1916,
To help get your crosswords printing again, it’s important to distinguish between the two different "connections" Alexa uses. Depending on the command you use, Alexa needs to talk to either your Amazon account or your Canon account.
| Command | Account Required | Common Fix |
| "Alexa, print a crossword" | Amazon Alexa Account | "Alexa, discover my printer" |
| "Alexa, ask Canon to print Sudoku" | Canon ID / IJ Cloud | Re-link the Canon Skill in Alexa App |
As a first step, I recommend telling Alexa to "discover my printer" and then trying to re-link the Canon skill in the Alexa app. This ensures both "handshakes" are active.
Let us know if the printer gives you a specific error code like "Cannot connect to server" when you try these!
Of course, if you get stuck, or if you feel this is too technical for you, you're welcome to give our team a call at 1-800-OK-CANON (800-652-2666), weekdays from 9am to 6pm (ET).
Phone support is free while you're in warranty. Out of warranty phone support is $20 - paid prior to calling within your Canon Account at https://canon.us/account
