02-24-2026
05:37 PM
06:47 PM
StevenMOD
TS3722 printer how to fix "P 1" code?
02-24-2026 06:46 PM - edited 02-24-2026 06:47 PM
P1 is not a specific code that points to a specific problem with your printer, so it could be caused by any number of things so to narrow it down if possible start here, if nothing helps or if a second error should arise let us know.:
The "P 1" error code on the Canon Pixma TS3722 typically indicates a problem with the printer's internal settings or a hardware issue. Here are some steps to troubleshoot and resolve this error.
03-10-2026 02:54 PM
3/10/26
i followed above instructions. i checked to update firm ware. It requires to print, obviously can't do that. other option is to press a specific button. it dodn't specify. i pressed all buttons and it didn't work. 😞
03-12-2026 11:00 AM
Hi CanonSD,
Please open the cover to your printer. Once open, please remove both ink cartridges.
Close the cover, turn your printer off and then back on.
Does a different error appear?
If the error that appears is E 0 4 or E 0 5 , please replace both ink cartridges with new, genuine Canon ink cartridges. Your PIXMA TS3722 is compatible with the following ink cartridges:
PG-275 black
CL-276 color
PG-275XL black
CL-276XL color
They are available for purchase here: Ink for your PIXMA TS3722 - usa.canon.com
If the P 1 0 error appears with no ink cartridges installed, your PIXMA TS3722 would require service. If your PIXMA TS3722 was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA TS3722 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support.
If your PIXMA TS3722 is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
03-25-2026 07:52 PM
3/25/2026 Canon Patrick Product Expert,
I followed your instruction of first taking the color and black inks off. Now it is showing "P 0 2" error. What's the next step?
03-30-2026 09:34 PM
3/30/2026 Canon Product Expert
I followed the link your product expert patrick gave, https://mycanon.usa.canon.com to contact a technical support representative. it made me pick a way to sign in (facebook, google, apple, even my emai;?) why is that? i tried through apple sign in and it won't work. i am not comfortable as i dont want my other log in to be compromised by phishing networks. to create a canon tech support account. i need to create a new account asied from this community canon support account? i'm confuse. would anyone walk me through this? - CanonSD
03-31-2026 03:07 PM
Hi CanonSD,
The P 0 2 error can occur if there is a smudge on the encoder inside of your PIXMA TS3722.
Please follow the steps in this Knowledgebase article to clean the encoder inside of your printer:
Cleaning the Encoder Film - TS3700 Series
