06-12-2023
01:57 PM
09:24 AM
I changed out my empty ink cartridge and replaced it with a new 275XL black ink cartridge. It’s the exact same model I had been using. Now the printer won’t recognize it so I can’t print. The printer is model TS3522. What can I do to get the printer to recognize it?
06-14-2023 03:02 PM
I recommend performing a reset of the printer. While the printer is on, unplug the power cord from the printer. While the power is off, press the power button 5 times. After 60 seconds plug the power cord back in and power on the printer.
If the ink is still not detected, try holding the stop button down on the printer for 5 seconds then release it.
Should the issue persist, I recommend reaching out to Canon support for real time support with this issue. You will need to register your Canon gear HERE to access additional support options.
