02-01-2024
01:30 PM
01:35 PM
I need help with a TS3322 printer, it used to work but I bought a cartridge recently, I put it in but it says E05 and I don't know the reason. Could you help me?
02-05-2024 04:23 PM
Hi ildeeeeee6,
The E 0 5 error is an indication that your PIXMA TS3322 does not recognize one or both of the ink cartridges installed.
https://ij.manual.canon/ij/webmanual/Manual/All/TS3300%20series/EN/UG/ug-127.html
Please open the cover to your PIXMA TS3322 and remove both ink cartridges.
Please make sure that the orange tape has been removed from the bottom.
Next, please verify that you are using ink cartridges that are compatible with your PIXMA TS3322.
Your PIXMA TS3322 is compatible with the following ink cartridges:
PG-243
CL-244
PG-245
CL-246
PG-245XL
CL-246XL
If you continue to have difficulties, please contact our support group using the following link:
https://mycanon.usa.canon.com
Once logged in, click on your product and then the Get Service & Support button.
When that page loads, click on either the Phone Support button or the Chat Support button.
