11-27-2025
01:10 AM
08:27 AM
StevenMOD
I have been printing from my Chromebook for years. Now when I try to print, I am getting a message Cannot connect to printer. I don't know if the printer is connected to WIFI, so I don't know if the problem is that the WIFI is not connected to the wifi network or is the problem with connecting the printer to the Chromebook. I don't know why this is now beginning to be a problem.
I would like to connect to the WIFI router by using the password for the router. I can'f figure out where the problem is. The Chromebook, the printer, or the WIFI
11-27-2025 10:27 PM - edited 11-27-2025 10:31 PM
If you can log any other device off and back on to the router, the issue is most likely not the router.
This may help:
To connect your PIXMA TS3322 printer to a Chromebook, ensure both devices are on the same Wi-Fi network, then add the printer through the Chromebook's settings. If needed, you can also connect via USB or install the appropriate printer driver from the Chrome Web Store.
| Method | Steps |
| USB Connection | 1. Connect the printer to the Chromebook using a USB cable. 2. Ensure the printer is powered on. |
| Wi-Fi Connection | 1. Connect the printer to your Wi-Fi network. 2. On your Chromebook, click the status area (bottom right) and select the same Wi-Fi network. |
Following these steps should help you successfully connect your PIXMA TS3322 printer to your Chromebook.
