Correct Install of Printer Driver for Pro-200 and MAC Computer
mckinney3
I am "getting up to speed" on a Canon Pixma Pro-200 Printer.  I see articles that suggest that the correct printer driver may not actually be running when installing to a MAC running os 13.4 (Ventura). Maybe AirPrint is installed instead.
I suspect this as:
1.  The Canon Pro-200 dialog from the MAC preferences tab only offers General and Supply Levels in the dialog and I see no UTILITY option.
2. Under KIND, I read  Canon PRO-200 series - AirPrint
Without the Utility tab, there are printer set up options and changes that I am unable to make.
I found a Canon document that references this issue but when I follow the instruction for installing the proper driver , I am unsuccessful and see the same info as I reported earlier.
What should I do to properly install the correct print drive and be able to run Canon IJ Printer Utility2?
6 REPLIES 6
jrhoffman75
Welcome to the forum.
1. download and install the appropriate driver for your operating system from this site: Canon Support for PIXMA PRO-200 | Canon U.S.A., Inc.
2. In System Settings->Printers & Scanners select the option to add a printer and wait for the Canon printer driver to appear. It could take several minutes. Generally the first driver to appear is the Apple AirPrint Driver.
3. After the Canon driver appears delete the printer version that is AirPrint.
mckinney3
Thank you very much.  This helped me.  A must is to use the proper driver and not select to soon which will be the AirPrint driver which will be incorrect.
Red River Paper provided this link which provides a detailed guide!
https://www.redrivercatalog.com/infocenter/how-to-fix-missing-paper-media-type-selection-osx.html
Question is about print drivers and PhotoShop Settings.
I run 2 Macs iMac _ Ventura  and Air book _Sonoma
Canon Pro 200, I print wirelessly.  I have been using AirPrint.  In the printer Setup dialogue _ P.S. Manages Colors, In Printer Profile _ I use Red River icc for the type of paper.
I installed the Canon V.26 software as a second driver for the Pro 200.  Question when using v.26?
Do you use PS to manage Color or the Canon Printer?  Do you use a Paper Profile or Printer profile
Does Ventura or Sonoma make any difference?
I have a Pro-100, but that shouldn't matter.
1. I never use the AirPrint driver. I always use the Canon IJ Series driver.
2. Print via WiFi from my MacBook Air and via cable from my Windows PC. My wife prints via WiFi from an iMac.
3. MacBook Air is running Sonoma. Wife's iMac running Monterey.
4. No problems from printing from any of the machines.
5.I use Lightroom, not Ps.
6. Since I use canon papers and third-party papers, I standardize my printing process. I always have LrC manage color and select the ICC profile and media type, even when using Canon papers.
Thanks for rsvp.
I'm testing a few variables within v26 driver.  Will post if I see appreciable difference between settings.
Wow! I was having a huge problem printing A3+ on my new Canon Pro-200s . I have had a trusty Pro 100 since 2007! I print 2-10 pages a day on that .. how could it last so long 😉 ANYWAYS ... through researching for hours and not seeing a drop down menu listing A3+ in my PS printer options I realized through you that the problem might be airprint. I did not realize that it was using that and not the plain Canon software. I deleted the driver and reinstalled a few times. finally after 3 or more tries it stopped using pro 200s airprint and just used the normal canon pro 200s . Finally. so now I believe everything is working thanks to you. i did nt realize airprint could leave some paper sizes off etc .
Thanks for saving the day . i rarely comment but hope if anyone else has this isue they can fine our messages here .
- Aaron
