11-06-2023 09:27 PM
It's been a while now that my 8620a keeps trying to print from the rear tray and error shows up on every single print job saying no paper in the back tray. I've already restarted the printer and no luck. Feels like some sort of sensor in the back is broken and makes it think it's open while the back tray is fully closed.
11-27-2023 07:38 PM
Are you using a Chromebook?
If so, see https://support.google.com/chromebook/thread/241195485?hl=en
11-27-2023 09:52 PM
No. I happened on Win 10, 11, and 2 Android devices.
12-12-2023 01:07 PM
Please turn off the paper mismatch setting on the printer using the steps HERE and let us know if the paper still has a message about using the rear feed.
04-29-2024 12:41 PM
Im having the same problem, printing from iMac running 14.1.1 - I have restarted printer, followed directions to turn off paper mismatch setting (as above) - no joy. Keeps trying to print from the rear tray no matter what.
05-08-2024 08:30 AM
Hi jleinung,
There is a setting on your printer that will specify the size and type of paper loaded in the rear tray and in the cassette.
If you set the rear tray to a paper size that you are not using, then the printer will feed paper from the other paper source.
For example, if you set the rear tray to 4" x 6" and the cassette to Letter, when you print with letter size from your Mac, the paper will be fed from the cassette.
To set the rear tray to 4" x 6", please follow these steps:
1. Tap the gear icon.
2. Tap Feed settings.
3. Tap Rear tray paper settings.
4. Tap Change.
5. Select a paper size that is NOT the size you wish to print with.
6. Select a paper type.
7. Tap Yes.
Once set, please attempt to print.
You can also specify the paper source in the application that you are printing from.
Let's take TextEdit as an example. Click on File and Print and scroll down to the Media & Quality section and change the "Feed From" from "Auto Select" to the location of your paper in your printer.
10-08-2024 05:32 AM - edited 10-08-2024 06:00 AM
Hi Patrick or anyone else,
I have the same problem with my TS9000 printer and none of your fixes worked. Even when I choose 4"x6" for the rear tray it did nothing. The big mistery is that it was still working 4 hours ago and now it suddenly stopped working i.e. wants to print from rear tray even though I have paper in the cassette. I also tried uninstalling and reinstalling the drivers and it did not help. Is there even a solution to this? I am trying everything.
01-03-2025 08:12 PM
I have the same issue. Worked for one print, then decided to stop all printing based on some rear paper feed issue. If I load paper in the rear feed it says missing rear paper. I changed the feed settings on the printer, changed the paper settings, and selected the correct paper source on the computer. I updated software and did the whole restart unplug, etc. No success. MUCHO frustrating.
