PIXMA TR8620a How to Scan Multiple Pages Into a Single PDF
mesav
Hello,
I recently purchased a pixma TR8620a printer. I am trying to scan some documents. How do I set it so that I can scan multiple pages into a single pdf?
Thanks,
Mike
ArthurJ
You will want to download and install IJ scan Utility from the Canon website. This will allow you to scan multiple pages into 1 pdf file. Please click HERE to access the support page for your printer.
9 REPLIES 9
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know which operating system is running on your computer (i.e. Windows or macOS and which version). Any
other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
It's a macOS
ArthurJ
zwright
Having a similar issue with scanning multiple pages from the printer control panel and paten. I have followed the steps here and do not get the option to continue scanning. https://ij.manual.canon/ij/webmanual/Manual/All/TR8600%20series/EN/UG/ug-060.html
Using Mac OS Ventura, all drivers installed and up to date.
If you have the paper directly on the platen glass, try loading the paper in the automatic document feeder and then select the scan option.
I am scanning 2 sided documents so I need this to work on the platen if possible.  Is there a way for this to work? My Provos canon (Maxify 2320) did this without an issue. I don’t understand what I’m messing with the pixma.
I would like to be able to use the platen to scan multiple pages into one document, using the operation panel, as I did for many years with my MX922.  How is this done with the TR8620a?
jfire7887
