06-06-2022 11:32 PM
I bought my TR7020 almost a year ago. Last month I got 5G internet. I changed the printer's LAN settings to the new network and confirmed that its SSID is now Verizon 5G. And it has been printing flawlessly ever since. Wonderful! Scanning is not so wonderful. I can scan from the Canon app on my phone just fine. But if I try to scan from my laptop I get the message "IJ Scan Utility Lite failed to open a connection to a scanner." What's wrong and how might I fix it?
06-08-2022 04:05 PM
Hi Raider13,
To resolve this issue, please follow these steps:
1. Please press the OK button on your PIXMA TR7020 1 time
2. Use the down arrow to select LAN settings and press OK
3. Select Wi-Fi and press OK
4. Select Advanced and press OK
5. Select TCP/IP settings and press OK
6. Select IPv6 and press OK
7. Select Yes and press OK
8. Select Enable/disable IPv6 and press OK
9. Select Disable and press OK
06-08-2022 04:05 PM
Hi Raider13,
12-20-2022 11:25 AM
This also worked for me when using my IMAC wirelessly connecting to the TR7020a...
